Looking for a little help with tuning using HP Tuners
FYI 65 Chevelle with 04 LQ4 .020 over with eutetic postons,04 ZO6 cam,Dougs headers,Walbro external pump with Corvette Reg.F Body
I used HP Tuners VCM edit to remove the VATS security,the rear oxygen sensors,all evap system and fuel related items.Reset the transmission to no for RN123D(running a 200R4 trans).Vehicle starts and runs very rich.Also has a large lope in the idle like it has a big cam in it(running a 04 ZO6 cam).On the short trips around the block it seem to do ok at part throttle,does not like to be pushed hard.Then as I am pulling it into the garage, it has died once or twice.
Ran VCM scanner.Still getting some fuel system codes.My timing is all over the place.7-22 degrees.I am pretty sure the cam is 2 degrees advanced.
I was looking for a "HP Tuners for Dummies" link on line but no luck.Seems like there would be a huge owners manual the size of the Bible with the HPT but nothing.
Now what do I do?Any help/direction would be appreciated.
Exactly what you asked for. HPTuners programming for dummies.
http://www.ls1lt1.com/forum/archive/...php/t-726.html
Here is another place to check.
http://www.hptuners.com/help/index.h...to_user_sd.htm
