94+ harness on 93 car?
Will an engine harness from a 94+ LT1 work with a 93' motor? What needs to be done to make it work? I fried my harness and I'm looking for another one but I can't really find any 93 harnesses \= so ill have to suffice with a 94'+. Any info on this would be greatly appreciated. Thanks in advance.
I've never done it, so this is just guesses:
I have no clue if the harness will even plug into the ECM since the 93s EMCs were different then 94s?
93 is batch fire, so I'd assume you'll need to change how the wires run between the EMC and injectors. Oil sending unit is located differently, probably need to add to the wires for it?
