LS1 injector/rail clips?
I had to swap out my LQ9 truck intake/injector/fuel rail for an LS1/intake/injector/fuel rail.
I've got the full LS1 setup, but there's no clips between the injectors and fuel rail. Are there supposed to be clips on the LS1 (2002)? Are they the same as the truck intake injector clips?
Anyone got a part number for them?
Gary
Gary
There is no clip on the Fuel rail itself to secure the injector. The electrical connector (Pigtail) for the Injectors have a clip integrated on to the connector that would secure it to the injector. The injectors are just press fitted into both the Intake and fuel rail with only O-Ring. The Fuel rail is then bolted down to the intake to keep all secure.
If there is no square shape clip in the injector connector, either your wiring harness / connector are missing the clips or someone has removed them. I am not sure these are serviceable parts and may not be replaced, check with your local parts shop (catalog) or at the dealer.
