adding some timing on 125 shot??
Thinking of adding a few degrees on my 125 shot. Im running 22 degrees right now with no problems. NA its running 31 degrees...so Im pulling quite a bit. What do you guys think I can get away with on 93 pump gas?? Im thinking 24 degrees...
wow 31* na seams high.
but i was gonna pull 3* for a 150 dry shot on my cam only car total timing is 26-28 not 1005 sure.
put it on a dyno add timing till the power peaks, then go down 1*
Yeah...It usually sees 29-31 degrees NA..Thats where it made the most power without any problems on the dyno.
