New noise in suspension
Front driver side makes a noise when the suspension rebounds. I can only hear it when going slow. The upper control arms are poly and lubed well. The lower are rubber everything is less than 4 months old. Sway bar end links are poly also. The sound seems to be coming from the top around the upper control arms. I disconnected the spindle from the upper ball joint and moved the uca through all of its motion and no noise. I moved everything else as much as possible and nothing. I then relubed everything and drove the car. Couldn't hear the noise when driving like before. Got home and bounced the car up and down and it was still there.
Noise sounds like a bed rocking back and forth on a good night. (couldn't find the smiley of the two people in bed)
I figured it out on my car. Strut mount isolator, the little $16 piece that you have to buy seperate from the Strut mount. The only other thing I did was re-torque the upper control arm bolts.
