Stripped Bolt Input needed...
Hey guys I was trying to get my new ls6 on the motor stand this afternoon. i got all the supporting bolts tightened down with a 1/2 drive ratchet...so nothing big. When i did a final once over one of the bolts kept spinning and spinning and spinning. When i backed it out the threads came with the bolt. So basically the hole in the block that you bolt the trans bellhousing is half nothing then half threads...i searched and read something about helicoil or w/e but not sure what to do with this...
