Needing more H.P.!!!!
100hp dry shot vs. bone stock ls1
my car is bone stock w/a4 and im wanting a 100shot or so to squash a few bugs! needing thoughts and opinions, and suggestions on what and how i need to do this. thanks guys
how many miles are on the car? How well does the car run, any smoke, how well has it been maintained. If there is nothing wrong with the car then you could easily run a 100 shot without any problems whatsoever.
Guest
Posts: n/a
Depending on how the car has been maintained and if it's not showing any signs of blow by a 100 - 125hp shot could be done easily. IF you decide to spray the car my suggestion would be to go with a plate system. The reason I'd suggest that is if the car has high mileage the plate system will net you a better atomization and more even cylinder distribution over a single and dual nozzle. Other than that depending on mileage you might also thinking about upgrading the stock in-tank pump to a racetronix system which will net you fueling capable of supporting around 630rwhp.
-Chris
-Chris
