LMR Custom Twin 67mm Initial Start Up Vid!!
Thought some of you might like to see the start up of our latest project. Car is equipped with a solid roller 408, custom LMR twin 67mm turbo kit, Burkhart Chassis 9in, Afco shocks on all four, RPS carbon on carbon clutch, Wilwood 6 piston calipers, and a sheet metal intake plumbed with a dry fogger just in case. Can you say Supra Killer!
http://www.youtube.com/watch?v=nr1PJ5qZ54s
LS1TECH Sponsor / 7 Second Club
The wiggens clamps are pretty expensive. They work very well though. I have one on the race car and it is holding up very well. To attach them I just weld the ferrule on to the TB.
I almost went with one of those after seeing it on a buddies Supra, but decided i liked the custom "multiple" guage look better. That thing is sick though, looks like you guys did an awesome job.
Any goals as far as track times?
You could put a race pak in pretty much anything. If you wanted to use the stock pcm you could just get a racepak data logger to control the dash. So yes it could be used along side a stock PCM
As far as track times I hope to see low nines high eights out of it. It is a six speed. I also hope to run the texas mile with it and do 225 or better!!
