C6 Z06 Procharger, LG LT Header W/ Hi-Flo Cats.. Injectors???
Old 07-09-2008, 05:07 PM
iMpoSStoR's Avatar
Default C6 Z06 Procharger, LG LT Header W/ Hi-Flo Cats.. Injectors???
We'll we strapped down the Z06 today but found out the injector duty cycle is at 116%.. I called procharger and they said to put some FAST 65# injectors.. my only question is will we be able to tune for 65 pounders with hptuners???.. or what injectors will we be able to get away with??.. any help will be greatly appreaciated.
Old 07-10-2008, 04:17 PM
YellowToy/A's Avatar
Will the fuel pump push that much fuel? 65# or 70# will work if you are not makeing that about 750 HP. Yes you can tune for that with HPtunes. That least with an LS1 OS.
Old 07-10-2008, 05:08 PM
Frost's Avatar
have to do some MAF/virtual VE trickery to run larger than 60s. Maybe see if you can get on the beta list for the 2/3 bar e38 OS with HPT.
