Window Down
Window Down
My drivers side window switch died on me, while the window was all the way down. i have to leave it parked outside until i can get it fixed... is there any way i can manually raise it? its not just the weather im worried about, its the people living around me. any help is appreciated, thanks.
It is a really simple install, but you can do half of it now if you want.
If you remove the motor, you can put a C-clamp or some object under the arms to keep the window raised. It might not be all the way but will be better than nothing.
