is it worth it? ed 6.5 subs and aftermarket system
hey guys would it be worth it to get a set of ed 6.5 subs for the rear sails in my car? the car has a full aftermarket system in it this is what i have.
alpine 7892 hu(might get another hu soon)
memphis belle 1300 5 channel amp 75x4 @ 4 ohms 115x4 @ 2 ohms +600x1 @ 2 ohms and the memphis amps are underrated so they put out a little more power.
mb quart premium series 6.5 componet set run off the front channels of the amp.
no rear speakers for now.
2 12in memphis pr's in a subthump well box and are geting about 600+ watts and they hit good but is the cheaper part of the system compared to every thing else.
so should i go with the ed subs to get some mid bass? i try to keep a lot of bass out of my front componets to keep em sounding clean and it all sounds good just seems to be missing some thing. if i do get them they will get about 115 watts a piece rms or maybe a little more.
i like strong mid bass and my benz has the harmon kardon upgraded stereo and the door speakers put out a lot of mid bass and even with an aftermarket system i cant get close to how the mids in my benz sound.
my rear sail area is already deadened and my doors are sealed decent but i have the foam speaker baskets in my doors because when i wash my car my mid will get a little wet so i put the foam things(not shure what there called). and it does sound better with the foam baffles so i guess they act like a sealed box. any one got any more input?
and thanks pentavolvo.
Since your going with an aftermarket amp the eD's would not be neccesary as they are DVC. With the aftermarket amp you can go with whatever you want. The eD's are usually the answer for the sails because they are DVC and the stock Monsoon channel in the Firebird is DVC.
If your looking for really solid midbass and then some I have the CDT M-6 and the ES-06+. These produce great bass reproduction and are exactly what you are looking for. The M-6 even has 10mm of excursion while the ES-06+ has about 14mm. All that from a 6.5" driver. I can do the M-6 for $199.00/pair. The ES-06+ I can do for $249.00/pair on special.
Here are some pics of the ES-06+. This is CDT's top of the line 6.5" driver.
This is the M-6:
This is the M-6:
