Opinions On Weird Noise
I installed a new 4.10 motive gear and Auburn High Performance posi into my ten bolt in April. After the install I started getting this weird noise when I would make a right turn with no throttle, it sounds almost like a rubbing/whining noise. It stops as soon as I give it a little throttle. It is pretty loud. It has been 600 miles since the install and I have pulled the cover to inspect the set up twice and it looks perfectly fine. Someone told me it is probably just the limited slip going around corners, but why wouldn't it do that turning left? Any suggestions. Oh and all the axle bearings look good too.
