what lines did you use out of the propotioning valve?
Location: where ever i can store my car. (palos hills,il for now)
ok i am about ready to knock this car off the jack stands. i ran new lines in the front and new in the rear. i was trying to bleed my brakes and the line that comes off the master into the wilwood propotion valve is squirting out. it looks like it takes a an fitting not a regular flare! what did you use?
no the next question i ran the braided lines that come with the brake kits. and the fittings that come with it also. now the brake fluid is leaking form all the areas where they connect. i was told that they go from a 3/16 fitting with an inverter flare (female) to the the -3an (male). and that is how they are set up. all of them are leaking.
what the f*** am i doing wrong.
thanks for all the help
cliff
cliff
Kleeborp the Moderator™
I had problems with my ABS delete until I realized that I was not cutting the hard lines perfectly square (which takes some effort to get just right). It was screwing up my double flares, and damn near every one was leaking. I took my time to get the lines cut square, and it never leaked afterwards.
