Harlan two step - wiring diagram needed
I can't seem to find one. If anyone has a wiring diagram that they could share I would appreciate it.
I have the following currently wired.
TNT F1 wet
Harland Window Switch
WOT Switch
TNT F1 wet
WOT Switch
Here ya go ........ I hooked mine up off the clutch peddle. I love the Harlan 2-Step
http://i6.photobucket.com/albums/y21...2_S_Page_2.jpg
http://i6.photobucket.com/albums/y21...2_S_Page_1.jpg
Thanks Randy, Do you have it wired into your nitrous system? I now have the 2 step wired, just trying to figure how to link the relay from the nitrous to the relay for the two step. Basically I need to deactivate the nitrous relay while the two step relay is active. Anyone?
ok, so I found this diagram https://ls1tech.com/forums/attachmen...1&d=1110007359 Can I just connect the two Micro Switches to my nitrous activation button?
I want to verify this diagram will turn the nitrous system off while the two step is active... Anyone confirm that?
Where does the WOT wire into this diagram?
The nitrous Wire from the 2-step is a ground and when you activate the 2-step you loose ground(-). I wired mine threw the nitrous solenoid relay ,and Wired my 2-step on the clutch pedal ,the wire goes to the ECM. I push the clutch in and then press the momentary switch on my shifter to activate it ,and hold the gas pedal to the floor , and hold on!!!!! . If you need to deactivate it, while the clutch is in gauged just push the button again ,that will deactivate the 2-step.
You can test the wire with a meter, Just take the 2-step wot wire and tie it to the ground (-) of the meter and take the positive (+) lead of the meter and hook to the battery, Set your 2-step at around 1500rpms or (above idle) so you don't haft to over rev while testing. And watch the meter when you activate the 2-step the meter should show (0-Volts) and when you release the clutch pedal it should show 12V. Remember the 2-step WOT wire is a ground (-).
