Ploy Mounts..direction??
Old 07-23-2008, 09:05 PM
Pro52R's Avatar
Default Ploy Mounts..direction??
Hey Guys,
I bought my mounts from a guy,but don't have instructions. i put them in the clams already,but..
I have searched a shitton, and cannot find any pics.
The mounts themselves are sorta off-set. Does the gap go towards the front or rear?
What I mean is it looks like you can set the engine forwards or backward like 1/2in by flipping the mount itself inside the shell..
anyone??
Any help is appreciated, and needed, tryin to drop the engine in friday
Old 07-23-2008, 09:57 PM
djfargot's Avatar
alright....
there should be 3 holes/rivets on one side of the mount and 3 on the other. the side that all 3 holes are in a STRAIGHT line is the top side of the mount, and the metal tabs sticking out of the poly mount go towards this side. the other side the middle hole should be offset, this is the bottom side of the mount.
as far as the polyurethane in the mount not being centered over the metal inside of it, mine werent. both sides were the same, with the right side of the mount about 1/4 - 1/2 inch longer. i dont think it affects them, mine are in this way and are fine.
