9 engine codes can someone help me
p0131 twice
p0151
p0507
p1153
p0135 twice
p0153
changed the 02 sensor with ac delco ones and change the 02 extensions new fuel pump (255 walbaro) new plugs, wires ect. new crank sensor, cam sensor map sensor. car runs like crap and its a cam only car and i dont know what else to do. can someone else help me out, and my fuel pressure is at 48 psi. let me know if someone can help me out
p0151
p0507
p1153
p0135 twice
p0153
Runs like crap because the computer thinks the injectors should be flow X amount at 58psi, but you are only getting 48psi (i.e. you are way short on fuel). Hence all the error codes. Diagnose your fuel pressure. Re-confirm the pressure with a different guage if possible. Might need to check the installation since this is something you recently changed.
fixed it you all. it was the main line inside the tank. i used the stock one but after that i seen the install on a 98 and my buddy came over yesterday and fixed it for me and i put a rubber hose from autozone and guess what i have power again all power
