3inch intercooler pipe to TB
I have an elbow and 3" intercooler pipe for it that works perfectly and looks almost factory... PM me if you want to buy it and what else you might need..Also the throttle body itself is 4" and the MAF is 3.5" and then then pipe would be 3" so depending on what you want to do you would need some of it, all of it, or another adapter (elbow) if you are running a speed density tune with NO mass air flow sensor...hope this helps
