what else do i need for procharger install??
I just bought a used procharger kit ,twin intercooles and electric fan assambly(can i use my stock fan assembly), with hopefully all the hardware , what else do i need for installation, and what size injectors should i go with and what type(brand) of fuel pump and is ther any thing i should look for on head unit to make sure its good, i plan on changing oil obvidosly before i mount up but like i said what else do i need to start this project as far as parts?? cant wait to get it well another scam on e bay so i did,ent get it
Make sure the blower does not have so much play in it that the impeller can make contact with the housing, and that the impeller is not bent much. You won't know if the seals in the blower are good until you use it, unless you send the blower in to ProCharger to have it inspected.
As has been mentioned, go with 60lb fuel injectors, a Walbro GSS 340 fuel pump, and I'd use NGK TR6 pn# 4177 spark plugs gapped at .035.
You can find all of these items, as well as ProCharger piece parts here.
http://www.exoticperformanceplus.com...l?category=193 Bob
