Block swap LS1 to LS3, but how do i get more revs?
Old 07-31-2008, 01:42 PM
lstvr's Avatar
Default Block swap LS1 to LS3, but how do i get more revs?
Hi Guys, i have posted this also in GenIV but i might catch some other ideas, apologies if you've seen it there. I have swapped my LS1 block for LS3 thanks to outrageous oil consumption. I dynoed her two days ago and this was the result, the car (2600lbs) has monster torque but does die, i think too early. I modified the DART 225's i have on by smoothing the casting flashes in the runners and i opened the combustion chambers out to 4.070 and cc'd the chambers from 62cc to 65cc, this took comp ratio from 11.2 to 11.5. My LS2 manifold is lightly ported, as in the 3 moulding flashes have been leveled out so they are smooth. Exhaust manifolds are not ideal as they are a TIGHT fit but are at least 20" long and they are 1 3/4" dia. I would like her to rev to 6500 without the power dieing so soon. CRANK POWER BTW!!
Old 07-31-2008, 02:06 PM
7camaro7's Avatar
wooooooowwwwww, a tvr with an ls3
Old 07-31-2008, 06:06 PM
Johnnystock's Avatar
what he said
Old 07-31-2008, 06:10 PM
Phoenix 5.7's Avatar
ls2 intake is crap. get a fast 92 and it will pick up all over
Old 08-01-2008, 12:27 AM
03EBZ06's Avatar
That is just sick and I like it. Anyway, a diff engine, but I've got a FAST on my 402. Datalogs indicate increasing airflow until I hit 6500rpm. At that point it really hasn't let up much. The MAF is pinned at 440gm/sec otherwise I bet it would go further. GET THE FAST!
Old 08-01-2008, 10:19 AM
IrocZTransAm's Avatar
Ditch the LS2 manifold...Fast should help you crank that puppy up! I gotta agree with the other 2 Gents here, that manifold is holding you back.
