QUICK WAXING QUESTION
i recently purchase my 2000 ss and when it came for a wash i realized that it had a shinny very slippery and greasy code over it it mean i washed the dirt off and looks clean but wehn u observe it upclose u can run your finger threw and thers a greasy code over it and it takes some serious goin back and swepping it off im thinkin it could have been that wax code they gave it before i picked it up any suggestions guys i could be wrong and by the way its not my rags that i use cause ther washed after every carwash
Re: QUICK WAXING QUESTION
Same thing happened with 2003 Avalanche. I washed it and it still looked like there was something on there. I also noticed that it had water spots after very little time and they would not come off very easy. Since I washed with Dawn and re-waxed, no more problems.
Could also try a cut-degreaser solution (like mix it up with some water, so its not as concentrated) that'll also remove any bug/tar/grease/grime thats on the surface, but Dawn is probably a better route. And yeah, make sure when everythings dry, you throw on a coat of wax.
