Valve stem seal question
I’m in the process of swapping out springs and the Crane duals require the older style Valve stem seal. I was told that I can use the brown Valve stem seal (Exh Seal) on the intake valves too. Can I? Or should I switch them out for the correct ones?
Thanks!
Thanks!
