S91 402 tuned and running! Boost question
Old 08-02-2008, 02:09 AM
SuperZ's Avatar
Default S91 402 tuned and running! Boost question
Well I got my car from the tuner(Boost Performance) and the drive ability is great and running strong with 12-14psi
Question
12-14psi is the max boost this thing will see.I have a 17 pound spring in it and the WG never opens.The BOV isnt leaking and there are no exhaust leaks.Ialso took the filter off and even though it does run better with it off no more boost.
Any ideas?I need 18+psi.
Old 08-02-2008, 07:09 AM
theblur98ss's Avatar
What size is your dp? No vacuum leaks anywhere? What kind of power did it make?
Old 08-02-2008, 07:53 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Blow the wastegate shut or put a block off plate on it to see what happens. Also pressure test the intercooler system.
Old 08-02-2008, 08:14 AM
7 Second Club
Phil99vette's Avatar
How many RPMs have you spun it to?
Old 08-02-2008, 08:30 AM
NA$TY-TA's Avatar
So no boost controller?? Running it off the WG spring alone?? More info.
Kyle
Old 08-02-2008, 08:49 AM
7 Second Club
And are you 1000% sure its got a 17psi spring in it?
Old 08-02-2008, 12:29 PM
SuperZ's Avatar
its a turbosmart WG. I had two 7psi springs in there and then I put a 10 in there combined with the one of the 7s and the boost did not change.Ive ran the 10+7 combo before on my old setup and it boosted 17+ and I took it right out.
Down Pipe is a 5inch necked to 4 inch oval pipe under there car with a Dr.Gas 4 oval muffler
And yes right now its running of WG only
And have spun it only about 6200 so far.
Old 08-02-2008, 03:14 PM
Qwick98Z's Avatar
Use a mighty vac and check to see how much PSI it takes to open the gate, Pressure check for boost leaks, check the boost at the turbocharger then at intake manifold, check the BOV, exhaust leaks Bla bla bla.
make sure your WG spring set-up is not the problem
10# WG spring and a boost controler is the hot set-up
Old 08-02-2008, 05:00 PM
Mr.MartyStone's Avatar
What kind of numbers did you see on 12-14ish psi?
Nate
Old 08-02-2008, 06:39 PM
darrellk's Avatar
yeah gorge is a great tunner he is going to tune mine in a couple of weeks
Old 08-02-2008, 07:40 PM
Mike101's Avatar
Cody I want a ride...call me
Old 08-02-2008, 07:46 PM
frcefed98's Avatar
Man I hate issues like this.
I know you said there are no exhaust leaks, go back over all bolts on the hotside, v bands too.
Check the intake manifold, make sure one of the gaskets didn't pop out when you were installing it. I had this happen and it made finding the leak a tough one.
Pressure test the whole IC system from the outlet of the turbo to the TB.
Check the turbo for any FOD that might be lodged in there. Maybe a coupler is sucking shut under boost?
Hope you find it.
Old 08-03-2008, 02:07 AM
SuperZ's Avatar
Yeah i dont know what it is.I gotta get it figured out though
Quick Reply: S91 402 tuned and running! Boost question
