FRC, Vet to TA?
FRC, Vet to TA?
Hi, has anyone got a link that shows how to change the Vet Fuel Rail Covers to fit my Trans Am ?
Would they fit right on with just the lettering needing to be changed, or does it need cutting to fit on, and if so do the existing holes need filling etc??
Also, I guess putting a cover on the engine will make it run hotter, is this bad for performance ? Are there any disadvantages to adding these, apart from being in the way? Will they fit with my 2 point Strut tower brace on ?
Thanks for the help...
Mine just went on. I did not make any cuts.
I did have to un tape the fuel lines and run one on top the other under the driver side frc. On the passanger side I just bent the dip stick tube a little. Mine fit fine. I do not know why people cut them up?
