Dtc 1336.
Old 08-05-2008, 03:52 PM
superchannelkev's Avatar
Default Dtc 1336.
So, ill try to keep this quick and simple:
1.) battery blew up
2.) car wouldnt start
3.) found that comp. was probable suspect.
4.) replaced comp.
NOW the car ran fine for 30 mins or so (just at idle) turned it off and started up again maybe 5 mins later no problem. so i go to start it later on and it will crank but wont fire, its throwing dtc 1336 and from what ive read you need the car to be running to do the re-learn. I am using a snap on nemisys scan tool and everytime i clear the code it doesnt actually clear. would this code cause it not to run or am i looking at other issues that need to be figured out?
the engine is stock with 34k miles on it and has been sitting for a while collecting dust, but i drove it at the beginning of the year with no issues until the battery blowing up. :/
thanks for any help/input
