IAT mod??
IAT mod??
Im want to install the IAT tricker for my HSW 125 dry shot. I only need about 3 or 4 degrees or timing pulled. Right now Im on 28* I data logged a pull and got no knock but I want to be safe and still pull alittle timing. I want to wire the relay to the trigger wire off my window switch. I just wanted to know if theres anything I should kno before I install the IAT tricker mod?
I also wanted to know were do folks usually splice into the IAT (Near the sensor of at the PCM connector?).
Thanks!
Rob
Thanks!
Rob
I would put a relay in. I would have the window switch go to the coil. Then I would have a resistor switch in when the relay trips. This way you can have a know value at the bottom of the table. There are tables for timing and PE.
I finished the IAT timing trick mod last night. Now my question is when the relay is engaged the IAT's go to 136* but Im not seeing any timing being pulled (mind you this is at idle if that has anything to do with it). I havent done a WOT pull yet with the relay on. At idle im seeing about 22-24* of timing. Will this change while Im driving and engage the relay for the IAT tricker?
Iat
I have my IAT tricker set to make the car think its 140 deg out side. On my stock 01 operating system it pulls about 3 deg of timing set up like this. You can go in to the program and adjust the IAT vs timing tables to pull more timing than that if you have editing software. I have mine adjusted to pull around six deg. BTW. Its an easy cheap mod thats worked well for me.
