throttle body question
well the stock size lt1 t.b is 48mm now does the 52mm and the 48mm share the same type gaskets. i was told that the 52mm uses the same gasket as the 48mm is this true or false?????????i have changed out t.bodies b4 but never checked to see if same gasket. now i need to know
