Buying Used 6.0L Truck Engine...Questions?
Old 08-13-2008, 07:16 PM
B-Rad420's Avatar
Default Buying Used 6.0L Truck Engine...Questions?
The engine is supossedly a 2004 6.0L w/100K miles from a 2500HD. Is there a certain casting number that should be on the heads or block so I can make sure its a 6.0L. Also what should I look for when looking inside the block as I want to make sure there are no spun bearings. Thanks, Brad
Old 08-13-2008, 09:05 PM
stricker76's Avatar
Is the engine out? If so, look on the block behind the flywheel. It will have 6.0L cast into the block there.
Old 08-13-2008, 09:13 PM
GMCtrk's Avatar
6.0L is also stamped on the front right side of the block as well.
