Basanni true dual install
Has anybody installed their own true dual basanni set up? If so how was it, did you encounter any problems, what manifolds/headers did you use, also did you install cats thanks
Trunion King
If I had proper tools/lift, its doable to do it by yourself. Make sure you put the pipes correctly. At first I used the stock exhaust manifold/cats then upgrade to longtubes (Stainless works). I got pictures/videos in the stickies.
BTW, I later switched to V band clamps from my three bolt flanges. I have videos of the car w/ just stock manis and w/ longtubes. Its on youtube, just search bassani true duals.
