lt1 daily driver ?
Old 08-17-2008, 12:09 AM
fast414's Avatar
Default lt1 daily driver ?
hi there i was just wondering if a turbo 350 would be hard to put on a lt1 and this is a car that is driven on the highway almost every weekend, what would i be revving at with say 4.10 gears and does it hurt anything if i drive almost everyday with a manual valve body thanks matt
Old 08-17-2008, 12:18 AM
fergymoto's Avatar
Not having OD will suck. I didn't like 4.10s in my A4 with OD. What size tire will you be running?
10.5LT1's Avatar
Man you would be running at about 3700 to 4000 RPM @ 70mph with 4.10s on a 26" tire.
Old 08-17-2008, 08:31 AM
96capricemgr's Avatar
That is assuming no slip at the converter and reality is probably a good 4% slip or more meaning 3900rpms.
Old 08-17-2008, 08:38 AM
FASTFATBOY's Avatar
You need to get a 28 inch tall tire on it at the VERY least to drive around on.
It will wear the engine faster turning those kind of RPMs, get a good trans cooler on it.
I am considering the same deal but mine is not daily driven but with a 3.70 gear and a 28 tall tire.
D
Old 08-17-2008, 08:53 AM
28" tire and 4% slip and it is still 3600rpms at 70mph. Seeing as you will probably still want a 3500rpm or so stall I would expect slip to be more than 4% that is just the default on the calculator I use.
Old 08-17-2008, 10:42 PM
10.5LT1's Avatar
My cousin has a 80 malibu with a 358 with a TH350 behind it. & 4.10s. At 70mph he was turnin around 3900 i wouldnt put that kind of wear on my car
Quick Reply: lt1 daily driver ?
