Single Cutout vs Dual Cutouts?
I'm curious if dual cutouts will be worth the money. Obviously I want it as loud as possible. Below are two pics of where I would basically be putting the cutouts (not exact, just approximate). I have Shortys, an ORY & a LM. After I put on the cutout(s) I'm swapping out the muffler for a quiet one for when I need to drive quiet.
Just let me know if I should stick with one or go for the two.
Thanks.
Thanks.
If you were closer to me I would trade you my ORY with dual cutouts for your ORY. The previous owner put them in and I have only opened them maybe twice since I have had the car.lol
here is te best idea so far use the money that you would spend on the extra cutout and get a 4" flowmaster merge collector since that one pictured is junk. That way you will have a 4" cutout which will be plenty and you will have a better merge which will give you more power when it is closed then with either of the previous choices. Then have a reducer back to your 3" catback.
Either adding 1 or 2 cutouts is my only option. I'm not putting any more money in this car. So no longtubes or anything else that reconfigures my exhaust setup.
