Squeaky Sound from right rear shock
My car is making a squeaking sound from the pass rear on the car, I really started to notice this after I had sfc's installed. Any idea what could be causing this......?
Tons. Torque spec is 80 ft-lbs. From my experience, when I get a new squeak or rattle from the rear of the car, I always check (in order):
-Mike
- Lug nuts - 100lbs
- LCA bolts - 80lbs
- Panhard bar bolts - Not sure off the top of my head, but I think it's 55lbs on the nuts and 74lbs on the bolts
- Spring isolators - Make sure they're seated
- Swaybar endlink/U-bolts - 18lbs
- Torque arm bolts (I have a Moser 12-bolt, so I'm always paranoid that these will back out) - I forget the torque spec off the top of my head
- Brakes - Bracket bolts are 74lbs, slider pin bolts are 24lbs, I think
-Mike
