Going F/I?? forged low comp LS7 shortblocks $5,995.00
We are now offering our forged LS7 shortblock on an out the door basis. This is a must have item for anyone doing a high boost S/C or Turbo build, that needs to lower compression and replace the Titanium connecting rods with high strength steel units.
We use high quality Callies H beam rods, and you have a choice of Diamond, Mahle, or JE pistons
Full details on the shortblock assemblies can be seen here:
http://www.lmspeed.com/installedenginepackages.aspx
We can usually turn these around within 2 weeks, but if you need it faster, just let us know when ordering. This is the same shortblock assembly that we are using in our current 800 hp TT ZO6 build
Please feel free to let me know if I can answer any questions,
Yes there is weight increase from Ti to steel. However, that increase would be in grams
after balancing the crank for steel rods.Not a major weight difference in the end result.
