Pro Kit rear and BMR front?
Has anybody done this? The back naturally sits a little higher as you all know, so I figured on the 1.3" pro kit in the back and the 1" BMR on the front should be a nice even drop? Am I thinking wrong? Anybody done this?
Thanks in advance!
Thanks in advance!
pro kit drops the rear over 1.5"! They are not accurate at all. So if you did that it would sag i nthe rear really bad. Even if you get the pro it all the way around it will sag in the rear unless you add a hose around your top coil spring and keep the rubber isolators in to raise the rear up a little. BMR all the way around is a great look and level and DMS springs sit up in the rear a little but of you add a rubber hose around the top of the coil spring and remove the rubber isolator it will lower the rear just right! like this
