Fuel pressure regulator for eaton s/c setup?
Ok, I am going to be doing the Eaton M112 install on my 95 LT1 engine. I'm also using the OE cobra 39lb injectors with adapter plugs. My question is what kind of fuel pressure regulator would be best to use with a roots style blower to add adequate fuel pressure vs. boost? Thank you for any info/help.
