Nitrous cam??
Old 08-22-2008, 09:10 AM
ls1redline's Avatar
Default Nitrous cam??
Currently running a TSP 231/237 113 lsa. Ok with a 100-150 shot? If not recommendations please.
Old 08-22-2008, 10:04 AM
GrimReaper's Avatar
I ran the same cam in my TA with a 150 shot for 2 years without any problems. It would scream down the track on the jugg.
Old 08-22-2008, 10:24 AM
Untouchable436LS1's Avatar
Everything that i've been seeing from ticks "polluter" cam seems to be the next big thing in the world of cams..a little bigger than what your running but great torque numbers, youll be fine with the cam you have, but just throwing out a consideration
24x/24x and 61x/61x on either 110 or 112ls
Old 08-22-2008, 10:26 AM
JScamaro's Avatar
With that small of a shot you can run whatever cam you want. The one you currently have is fine.
Old 08-22-2008, 03:15 PM
Chris@NitroDaves
Guest
Posts: n/a
You will be fine spraying on that cam.
-Chris
Old 08-22-2008, 06:19 PM
5_02ls1's Avatar
no need for custom nitrous unless you are 175 or larger...
Old 08-22-2008, 06:33 PM
JBM
JBM's Avatar
My set up for 2009 will run around a 276/284 .765/.800 on a 114.
