Supercharger belts cheap?
Old 08-22-2008, 09:14 AM
phildo's Avatar
Default Supercharger belts cheap?
Is there anywhere to go to get a a 12 rib supercharger belt other than Procharger? I have checked around and it is hard to come by a 59" 12 rib belt. I just feel bent over with no lube when I have to pay $85.00 for a belt that cost $25.00 and will only last 3 months. Pm me if you have to.
Thanks
Old 08-23-2008, 10:00 AM
EPP
EPP's Avatar
Our prices on ProCharger parts are less than they are when going direct through ProCharger. Give us a call at 260 244-4808. Bob
Old 08-24-2008, 07:39 AM
forcd ind's Avatar
i ran a couple 6 rib belts once, direct from the auto parts store-i kind of liked them better than 1-12 rib, actually had less slippage
Old 08-24-2008, 09:15 AM
Jake@EPP's Avatar
Try going to a local napa and asking to see the belts, there should be a number on that 12 rib, but it may be a ATI only.
Start with something like a 25-120590 for a napa pn.
Old 08-24-2008, 10:11 AM
SS4Matt's Avatar
definatly go to napa and look up Gates HD belts, the HD's are green on the back sides. they held up extremely well on a friend of mines T-Trim stang (12 rib setup) pushing 24'ish psi. His car was snapping belts on a weekly basis until he found the Gates HD's and they were like $30 or something and he didn't have problems after that. the only problem he did have was it didn't make enough power so he ripped it off and built a turbo kit
Quick Reply: Supercharger belts cheap?
