L92 Intake Gasket #1222-2
Old 08-23-2008, 07:40 PM
bluethunder364's Avatar
Default L92 Intake Gasket #1222-2
Does GM or any other venders offer a intake gasket other than the fel-Pro
#1222-2 ? I had one hell of a time to get them off the head when I pulled the intake. They were stuck like they had been glued on (which they weren't)
Thanks
Old 08-23-2008, 11:00 PM
V8Rumble's Avatar
I suspect that you're going to run into the same thing that I have so many times - the engine is so new that virtually NO-ONE here is going to have any info. You post a question, & the only response you get is the sound of chirping crickets... (And I haven't even had time to fire my L92 up yet, so I'm not able to help you, although I sure would if I could...)
Best of luck though, I'd LOVE to be proven wrong...
Old 08-24-2008, 02:31 AM
1dirtyZ's Avatar
why not make yor own out of some other gasket material using the old one as a template ??
or why not try to lightly coat the gasket surfaces with grase so it won't stick the next time?
Old 08-25-2008, 02:43 PM
I thought about the grease, but wasn't sure if it would leak or cause some other issue
Old 08-26-2008, 05:56 PM
Oscar Will's Avatar
Summit shows a GM Performance gasket set for an L92, their stock #NAL-19172114
Quick Reply: L92 Intake Gasket #1222-2
