100 shot on stock tune
Old 08-25-2008, 09:21 AM
Platinum WS6's Avatar
Default 100 shot on stock tune
bad idea?
Old 08-25-2008, 09:26 AM
Nick@HSW's Avatar
Not at all. I would just verify a/f is in check and that timing hasnt been touched prior to spraying. Or if you still don't feel comfortable, then I would recommend pulling some timing to put yourself at ease.
Nick
Old 08-25-2008, 09:43 AM
i had a dry shot on it before and it did fine with a 75 but i am going to throw a 100 wet on it. it has the Hypertech program but last time I just detuned it back to stock and it did just fine ( a/f wise ) but with it being a 100 wet i just wanted to make sure it will be ok. thanks for the quick response!
Old 08-25-2008, 10:12 AM
Chris@NitroDaves
Guest
Posts: n/a
With the mods that you have spraying a 100hp shot will be ok. Like mentioned above it would be better if you could verify AFR but with what you have should be fine. If you were at all worried that you might run into problems spraying 100hp then you can always start off with a smaller shot and work your way up to 100hp so that away if there is gremlin it shows itself before your at 100hp.
-Chris
Old 08-25-2008, 10:47 AM
-Chris
yea i agree with that, i think i will start back at 75 and see how the a/f is there with the wet shot and work up...eventually to a 150. thanks for the input
