9" gear install question
First let me say that i've done a few installs on 8.5" 10 bolts before, but this is my first 9".
Im going to be assembling my 3rd member myself for my new 9". I've read through some install guides and the only thing that isn't completely clear to me is the setting of pinion depth. Do the shims go between the bearing and pinion gear, or between the case and pinion support?
BTW, im using a Strange S case, Daytona pinion support, detroit locker, and Summit gears. Its all new stuff, so i don't have a used shim thickness to go off of. I also do not have a pinion depth gauge so i'll be going off reading the pattern. Thanks
