Phamspeed kits any good?
It's all about ground clearance, plug access and to be able to keep your accessories. Most any hot side kit will be able to provide plenty of flow. Your combination and turbo will be the limiting factors. If you are refering to the kit WestSide has for sale I believe it is a very good overall kit. Stainless steel and already wrapped. Can't beat that price. I just don't recall if any of it runs under the K-member or not. I do know it was a step above the original budget kit which I had. Shy away from that one. The ground clearance was non-existant. My car is lowered but to give you an idea here's a pic of my kit with the car at normal ride height. The second pic is on the lift to simulate a stock ride height car.
