Help - MAP hose?
Old 08-27-2008, 01:21 PM
blownmiata's Avatar
Default Help - MAP hose?
I am putting my LS1 together, and can't figure out one hose. It comes from a (MAP? #10212460) sensor at the back of the intake manifold. It is maybe a 5/8"ID straight hose about 15" long toward the drivers side, with a push-in style elbow on the end. My best guess is that it originally went to a brake vacuum or booster? Can I just plug it? The GM number doesn't cross to anything.
Also, where does the cam position sensor plug in to?
Old 08-27-2008, 05:21 PM
ls1nova71's Avatar
That's the hose for the power brake booster, if your not using power brakes, then yes, you can take the hose off and just cap it. The cam sensor is at the rear of the block next to the oil pressure sensor.
Old 08-27-2008, 10:27 PM
blownmiata's Avatar
Thanks man!
Quick Reply: Help - MAP hose?
