what temp is stock for coolant relays
Old 08-29-2008, 04:06 PM
ssduane's Avatar
Default what temp is stock for coolant relays
What temp is relay one and two set to come on and off at. I had my PCM mail tuned for now and am not sure what the settings are. I have my relays wireed up from the PCM control and ran the engine up to 215 and got no power to my fans before I shut it off. Is it higher?
Old 08-29-2008, 05:49 PM
LS1-450's Avatar
I don't remember the stock settings, but, 190*F & 200*F aren't a bad idea. Even if stock is/were 215*F is, I'd lower it. Usually, stock thermostats & cooling fans are set-up higher in order to meet emmissions regulations. BTW, your oil temps are usually 20 to 25*F higher than the coolant. So my fans are based on optimum "universal standard" oil viscocity temp of 100*C or 212*F. This is the temp where most oils are designed to run. So, basically 190* ish is a good low fan on temp unless the car sees WOT road course pulls or 10-15 hard pulls on a drag strip track night.
Old 08-29-2008, 11:00 PM
bczee's Avatar
If I recall right, the stock temp that the PCM will turn on the fans is on at 226 and Off at 219 for #1 and for #2, on at 234 and off at 227?
With AC turned on, both fans should turn on..
Old 08-29-2008, 11:07 PM
ssduane's Avatar
I was thinking it was up there. Nothing is AC enabled now (wiring wise), so that should matter.
Thanks
Guess I'll pull the sensor and see if I can put it in a pot and hot plate to see if I'm wired good.
Old 09-02-2008, 06:05 PM
Oscar Will's Avatar
Mine is on at 210 degrees, will pull the temp down to 180 degrees before it shuts the fan down. It has been working very well for a long time. Of course with the A/C on it's a different story.
Quick Reply: what temp is stock for coolant relays
