stock 99 ls1 injectors provide any gain?
I was looking through the garage and found the fuel rail and injectors from my old 99 car, I know obviously I can't use the rail, but would there be anything to gain by swapping the injectors into my 96?
If you get it tuned for them, I think they're 28#. There probably won't be any real gain from them unless you have mods to support them, but you might notice some quicker response of the motor.
Also, I believe those use a different style connector, so you'd need to solder them in as well.
Good call, forgot about the PSI. LS runs 50psi doesn't it? So if it's 28 it'd be back to around 24, and if 26 then probably 22ish. Well let me retract that, 39psi is ford, LT is 43 and that's 4 PSI making around 1.5# change. So I guess with 7psi change a better assumption would be 2# change. There's calculators but I'm too lazy lol
