Air/Fuel Question
Old 08-31-2008, 04:57 PM
tatasta's Avatar
Default Air/Fuel Question
Hello,
I am running the mods in my sig and the N2O system is a Brand X wet nozzle kit with warmer, Dynotune window switch, fpss, blanket, purge etc. I am runnung a 100 shot at ~970psi and working on dialing the AFR. System works well.
Question is: When the nitrous hits the AFR is 12.0 and as the bottle pressure pulls down through the run, the AFR goes into the 11.9 to the 11.7 range.
Safe enough or should I re-jet the fuel or drop N2O pressure?
Also, car has 58 lbs fuel pressure and skipping spray in fist and w/s on at 3400 and off at 6k, for now.
Thank you!!!
Old 08-31-2008, 05:49 PM
b00sted's Avatar
Mid-high 11s is where you want to be. Seeing as it's only a 100 shot I don't think it will be an issue for it to run in the range it currently is.
Just pull a couple plugs after a pass and make sure it's not detonating.
TR6 plugs right?
Old 08-31-2008, 07:46 PM
Dragman's Avatar
TR6 plugs right?
I agree!
Old 09-01-2008, 07:27 AM
tatasta's Avatar
Yes, TR6 plugs are in there.
