Water Pump Gaskets
Old 09-02-2008, 02:25 PM
bigboykilroy's Avatar
Default Water Pump Gaskets
I have a 1998 LS1, I'm going to be installing a new cam and the 98 LS1's use the paper water pump gasket, the new timiing gasket kit comes with both the new metal o ring style and the old paper ones. I should be abled to use the newer style metal gaskets right?
Old 09-02-2008, 04:16 PM
blkbird's Avatar
Yes, the paper ones are crap.
Old 09-02-2008, 04:52 PM
I wonder why they give you both? i have installed cams on 99+ cars and the metal ones are much nicer, you would think they would do a TSB to replace them with the newer better ones....thats what i thought but wanted othes opinions as well. thanks !!
Old 09-02-2008, 08:04 PM
theblur98ss's Avatar
Yes use the new ones and make sure to scrape off all the old gasket.
