Obviously you are getting some wonderful times out of that setup! I had just one question for you, are you still using the stock crank in teh stock cube setup? or is it a forged stock stroke unit? Thanks
Thanks a ton! I'm just starting to question stock crank durability with large shots. How much was it for the nitrate process? That similar to the cryo process?
