starter wiring
starter wiring
I am wiring a '99 Miata with an LS1. Can I use the car's starter trigger wire from the ignition, or do I need to use the LS1 purple wire?
Also, if I can use the car's ignition wire to turn the starter, is there any reason to hook the LS1 (manual) clutch switch wire into the system, or can I again just rely on the car's clutch interlock?
On my '70 Impala with an LQ9, I have used the original wire from the Impala and it works fine: my harness was reworked by Speartech and they had labelled the purple wire from the engine harness "if needed".
I do not know about the clutch switch, I have an auto trans.
