LS6 & stock inj. --to--> FAST90 & SVO 30#
Old 09-03-2008, 04:49 PM
cdoggy81's Avatar
Default LS6 & stock inj. --to--> FAST90 & SVO 30#
I'm changing out my LS6 intake, ported TB & stock 28# injectors to a FAST 90/90 combo & SVO 30# red top injectors. Will the injectors work ok? Do I need any adapters to make them fit/work or will they plug right in? I'm going to use the fuel rails off my LS6. Thanks!
Old 09-03-2008, 05:31 PM
camaro_ss_97's Avatar
they should work just fine
Old 09-03-2008, 05:37 PM
12secSS's Avatar
Yup, they will plug in without a problem. Although you will need to change the injector flow table in the tune, as it will run rich without doing so.
Old 09-03-2008, 05:40 PM
good point 12secSS
Old 09-03-2008, 07:42 PM
cdoggy81's Avatar
Thanks guys. I planned on getting a tune anyway when I do the swap. I'm also adding ported & milled LS6 heads, a F13 cam, 1 3/4" headers & 2.5" true dual exhaust Those injectors should be enough still right?
Old 09-03-2008, 08:38 PM
yes they should be all you need
Old 09-03-2008, 10:18 PM
snake charmer's Avatar
the svo 30s run about 36lbs on our engines than ford cause of the fuel psi . i am still running 28.8 injectors on a similar setup .
Old 09-03-2008, 10:23 PM
12secSS's Avatar
Good choice! I have an F13 on my LQ4 in my SS. With the stocks, I was at 97% duty cycle on the injectors, now with the "red tops" (SVO 30#ers) I am at 87% duty cycle. Be sure to post up the results on the dyno section when it is done.
Old 09-04-2008, 07:59 AM
cdoggy81's Avatar
Will do & thanks again guys for the help!
Old 09-04-2008, 04:34 PM
silverLSWON's Avatar
what he said
