In need of a Fuel line fix
I have a bad kink in the hard return and hard supply lines under the driver seat...
What would be the best way to fix?
I have this regulator Aeromotive 13107 and i wanted to know if the fittings that are screwed into the fpr for our quick connect lines can be removed and replaced with some AN fittings so that i can run ss braided fuel line back to the filter and tank...
Which will keep me from having to make 2 flanges...
using these...
using these...
