Can you help with cooling set-up?
Old 09-04-2008, 12:14 PM
sevanseriesta's Avatar
Default Can you help with cooling set-up?
Here is the issue that I am running into. I have a custom twin turbo setup and I am trying to run my water pump hoses to my radiator that has been moved to vertical. My problem is on the water pump, where the thermostat housing is. It points towards the my down pipe. I have thought about doing a remote pump but have not really been able to find much info on it. I will try to post some pics of what I am talking about I have not taken any recent pics since everything is in and together. Anyone running a twin setup with the turbos where the battery and the fuse box's were please chime in!
I am running stock water pump, with a griffen radiator that everyone else runs. I was thinking of running a straight piece instead of an angled piece where the thermostat housing is. Better pics will come tonight!
Old 09-04-2008, 12:47 PM
Speed Inc. I know that you have had to deal with this on a couple of your setups any info would be great!
